Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Help updating the firmware of a Pix 515
I have a Pix 515 and wondered what files I need to update it to the latest firmware, I think I need 2 files.
Also I want to use the PDM or ASDM to manange it (along with the cli), would I still use the PDM or ADSM for later version of firmware?
1 REPLY
Re: Help updating the firmware of a Pix 515
If you are going to upgrade from 6.x to 7.x or above you have to meet bellow requirements in this link, and yes asdm will be the gui
http://www.cisco.com/cgi-bin/tablebuild.pl/pix
if you are going from 6.x to the latest on 6.x train the code would be 6.3.5 with PDM version 3.0.4, see same above link where codes are.
Highly recommend to go over the upgrade guide if you are going to 7.x as they are deprecated commands but are generally converted into new code equivalents during upgrade.
http://www.cisco.com/en/US/docs/security/asa/asa70/pix_upgrade/upgrade/guide/pixupgrd.html
Jorge
151
