HELP upgrade fwsm procedure
i need help for upgrade ASDM and Software of a FWSM.
My running software is FWSM Version 3.2(5) and i want to upgrade to last release.
ALso i want to upgrade ASDM to last release ASDM 6.2F.
Can some one explain me the exact procedure to upgrade the FWSM.
thanks a lot.
Everyone's tags (4)
1 ACCEPTED SOLUTION
Re: HELP upgrade fwsm procedure
Yes, sir. That's correct.
You can store images for both ASDM and FWSM on disk if you want to, but you cannot boot them from disk.
Thanks a lot,
the section that i must read is "Installing Application Software from the FWSM CLI" , correct?
But in ASA you download the image in DISK0:,here in the flashcard?
In ASA you must use command boot to specify witch ASDM or Software you want to load on boot, here i not specify nothing?
thanks a lot best regards.
FWSM unlike ASA does not have the "boot system ..." CLI.
It can only boot from flash:image
Marcin
So i need only to download the asdm and software version to falsh and that it......
correct ?
Thanks a lot.
Thanks a lot you are perfect.
Best regards.
5182
