Help with ASA 5510
We installed an ASA 5510 today and are having some problems. I can ping to the inside interface from my PC but can not get beyond that. From the ASA I can ping the outside workd no problem. Here is out config. Of course I removed our outside addresses, but they are correct as I can ping to and from them. Thank you for your help.
Jason
thompsonasa# sh run
: Saved
ASA Version 7.0(7)
hostname xxxxxxxxasa
domain-name xxxxxxxxx.local
enable password xxx
names
dns-guard
interface Ethernet0/0
nameif Outside
security-level 0
ip address x.x.x.x x.x.x.x
interface Ethernet0/1
nameif Inside
security-level 100
ip address 10.10.253.1 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
passwd xxx
ftp mode passive
pager lines 24
logging asdm informational
mtu management 1500
mtu Inside 1500
mtu Outside 1500
no failover
asdm image disk0:/asdm-507.bin
no asdm history enable
arp timeout 14400
global (Outside) 10 x.x.x.x-x.x.x.x netmask x.x.x.x
nat (Inside) 10 10.10.1.0 255.255.255.0
route Inside 10.10.1.0 255.255.255.0 10.10.1.1 1
route Outside 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 management
http 10.10.0.0 255.255.0.0 Inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd lease 3600
dhcpd ping_timeout 50
dhcpd enable management
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
Cryptochecksum:xxx
: end
Re: Help with ASA 5510
Got it. It won't work with a range of dynamic addresses. Any iedeas?
Jason
Jason,
You are only NATing the 10.10.10.0/24 network, so anything behind inside interface other than 10.10.10.0 will not be nated.
your statement
do instead for anything behind inside interface
nat (inside) 10 0 0
-Jorge
Jorge,
We are nating for the 10.10.1.0 network. When I put an address pool for the global addresses it fails. If I use PAT and use one address it works fine. Got internet access and inboung smtp working. Now I can not get OWA to work. This thing is going to kill me.
Jason
Jason, btw.. that's an old code.. I would at least bring it to 7.2 , I have read lost of weird things on 7.0.7 even though is on GD stage.
nameif Outside
security-level 0
What is x.x.x.x?
Could you make more wise replacement?
107
