Help with ASA logging
I'm on the ASDM of a 5510 and the logging with in the ASDM is currently set just right, but when I go into the console via SSH and use "term mon" I don't get this logging showing up.
Here are the settings:
logging enable
logging buffer-size 200000
logging console errors
logging monitor critical
logging buffered critical
logging asdm errors
As you can see I have set the ASDM and console to the same level.  Currently in the ASDM I can see a user getting denied access to a device, but in the console view I dont get that, which I woudl like.
  • Firewalling
1 ACCEPTED SOLUTION
Re: Help with ASA logging
Andy,
Using "term mon" duing Telnet or SSH sessions will show logs based on the 'logging monitor ' command, not the 'logging console ' command.
If you want to see the same errors you are seeing via ASDM, you can use the command 'logging monitor errors'.
Here's a Cisco doc on that command:
http://www.cisco.com/en/US/partner/docs/security/asa/asa84/command/reference/l2.html#wp1796033
Andy,
Many thanks!
640
