Help with basic ASA config with NAT issue
I'm just putting together a basic ASA config and there seems to be an issue with NAT.  I'm trying to ping a router past the outside interface 10.10.10.2 from an inside PC 10.101.61.10.
The ASA can ping it, can you see anything wrong with the below config?
ASA Version 8.4(2)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface GigabitEthernet0
nameif outside
security-level 0
ip address 90.174.83.202 255.255.255.252
interface GigabitEthernet1
nameif inside
security-level 100
ip address 10.101.61.1 255.255.255.0
interface GigabitEthernet2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet5
shutdown
no nameif
no security-level
no ip address
ftp mode passive
object network internal-10.101.61.0
subnet 10.101.61.0 255.255.255.0
object network Internal-0.0.0.0
subnet 0.0.0.0 0.0.0.0
access-list inside_access_in extended permit icmp any any
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-714.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) dynamic interface
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 90.174.83.201 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication enable console LOCAL
aaa authentication ssh console LOCAL
aaa authorization command LOCAL
aaa authorization exec LOCAL
http server enable
http 10.101.61.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh 10.101.61.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
dhcpd address 10.101.61.10-10.101.61.254 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username *** password *** encrypted privilege 15
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
crashinfo save disable
Cryptochecksum:4ce467cd868cc11bb408a997e3bf0fd2
: end
ciscoasa#
2 ACCEPTED SOLUTIONS
Super Bronze
Re: Help with basic ASA config with NAT issue
I would suggest adding a "permit ip any any" statement to the ACL as now its only allowing ICMP and nothing else. Or perhaps adding "permit ip 10.101.61.0 255.255.255.0 any"
You also seem to lack the default Policy Map configurations
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect rtsp
  inspect skinny
  inspect pptp
  inspect esmtp
  inspect icmp
  inspect icmp error
  inspect ftp
service-policy global_policy global
You probably need the ICMP inspections configured (like above) for the Echo Reply to get back through the firewall.
That or allowing ICMP return messages like Echo Reply, Time Exceeded, Unreachable through the "outside" interface.
- Jouni
Hello Andrew,
So the 10.10.10.2  is on the outside interface, is that what you are saying??
If that is correct let's add
fixup protocol icmp and try one more time.
If the PC is on the inside I do not see a route to that device, you will need that and also a static translation to the outside interface.
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Super Bronze
parameters
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect rtsp
  inspect skinny
  inspect pptp
  inspect esmtp
  inspect icmp
  inspect icmp error
  inspect ftp
- Jouni
Adding the default policy map also fixed it, would you mind explaining what this does?
Hello Andrew,
Jcarvaja
Thanks that did it.
Do I need to add a default inspection policy too as I don't have one?  What does this do?
Hello Andrew,
I would recommend to add it.
Use the command
clear configure fixup to add the default policy map and then add the fixup protocol ICMP.
This will allow you to statefully inspect the specified traffic at a deep level (taking into consideration RFC standards, timeouts, packet-size, etc, etc, etc).
Now the thing with ICMP is that this protocol is not stateful as TCP is so when we enable this we basically let the ASA know save the ICMP sessions into your stateful session and monitor the returning traffic so get's allowed dynamically without the need of an ACL.
Then whenever we receice an ICMP echo reply for an echo request the session will be removed from the State table of the ASA.
Jcarvaja
88
