Help with basic config for ASA 5505
I've tried so many config methods I'm not confused on the issue.
I have a DSL modem from Virgin Media and if I plug my laptop into it it gives me a public IP and I can get on the internet, it is doing some sort of DHCP.  Now I have put the outside of the firewall into this port and configured the ASA as best as I can but I can't get on the internet from the inside, can you think of any reason why it isn't working?
ASA Version 9.1(3)
hostname ciscoasa
enable password RHohe4nol/SZU8wm encrypted
names
interface Ethernet0/0
switchport access vlan 99
interface Ethernet0/1
switchport access vlan 10
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan10
nameif inside
security-level 100
ip address 192.168.0.1 255.255.255.0
interface Vlan99
nameif outside
security-level 0
ip address dhcp setroute
ftp mode passive
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network inside-network
access-list inside_access_in extended permit ip 192.168.0.0 255.255.255.0 any
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,outside) dynamic interface
access-group inside_access_in in interface inside
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcp-client client-id interface outside
dhcpd auto_config outside
dhcpd address 192.168.0.10-192.168.0.254 inside
dhcpd dns 4.2.2.2 interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
username admin password /duR4QE encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
2 ACCEPTED SOLUTIONS
Silver
I checked the interim release notes and I did not see any bugs related to 9.1.3 DHCP, suggestions to follow:
http://www.cisco.com/web/software/280775065/107119/ASA-913-Interim-Release-Notes.html
On the interface VLAN 99 we will set a virtual MAC address:
Enable
Config t
interface Vlan99
mac-address 001C.2314.14DA
Some ISPs might filter vendors as they only wish for you to connect a PC not a router/firewall or whatever device that will provide access to more than one PC.
Then is this does not work, upgrade to the latest 9.1.3 interim release if you can.
Nothing works just get me debugs and captures:
debug dhcpc detail
debug dhcpc event
debug dhcpc error
I think that you could set the capture like this:
capture dhcp interface outside match udp any any eq 67 match udp any any 68
If it does not work then just add the command like this and it will combine it:
capture dhcp interface outside match udp any any eq 68
Download the captures:
https://192.168.0.1/capture/dhcp/pcap
Let me know how to goes
Value our effort and rate the assistance!
Super Bronze
ASDM and the CLI command "show run route" doesnt show anything as you have not manually configured any routes.
The actual route shown in the actual routing table active now on the ASA shows the default route installed by the DHCP automatically/dynamically as it received the information from the DHCP server (ISP) as you defined the "setroute" parameter in the interface configuration.
When you are using DHCP you can't naturally set the default route staticly yourself as you wont know what public IP address and from what subnet you will receive from the ISP. So a staticly set/configured default route might be wrong and point to a gateway IP address that is not from the same subnet you received an IP address from.
- Jouni
Super Bronze
Check the following command to see if you have gotten an IP address
show ip add
Atleast I think that should show it
Then check if you have gotten the default route
show route
Double check that you have actually connected the port Ethernet0/0 to the modem since its the only port attached to external VLAN 99
If you are testing with ICMP add these configurations
  inspect icmp
  inspect icmp error
If you have not found any problem so far then check the actual host
Check that it has gotten the information needed with DHCP from the ASA
Check on its command prompt that it can resolve a name to an IP address with the DNS server used (4.2.2.2)
- Jouni
Here is what I have, not looking good:
show ip add
System IP Addresses:
Interface                Name                   IP address      Subnet mask     Method
Vlan10                   inside                 192.168.0.1     255.255.255.0   manual
Vlan99                   outside                unassigned      unassigned      DHCP
Current IP Addresses:
Seems I don't have a route.  I've used ASAs before on 8.2.x and I can set the route to the outside interface, what should I add on 9.1.3?
The host is getting DHCP and I can get on the ASDM and I have just configure SSH and that is ok, just seems it coudl be a route issue or the fact the Outside isn't getting an IP.
Silver
OK, connect the PC and get an ¨ipconfig /all¨ from cmd to see the IP that you get.
After you get that output we can decide if we need to run a debug to see what is happening.
This is what I get:
Physical Address. . . . . . . . . : 00-1C-23-14-14-DA
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . :  77.96.205.189(Preferred)
Subnet Mask . . . . . . . . . . . :  255.255.255.0
Lease Obtained. . . . . . . . . . :30 November 2013 11:55:09
Lease Expires . . . . . . . . . . : 06 December 2013 19:41:27
Default Gateway . . . . . . . . . :77.96.205.1
DHCP Server . . . . . . . . . . . : 62.253.131.201
DNS Servers . . . . . . . . . . . : 194.168.4.100
                                                194.168.8.100
I have to set the Virgin Media DSL router to modem mode and connect to the outside (Eth 0) of the ASA.  On the Laptop if I type 192.168.100.1 I can get to the Virgin Media DSL router to manage it.
I didn't put any IP in, it is all DHCP.
The outside interface is set as DHCP as the ISP router should assign it an IP like it does when the laptop is plugged, but I don't think it does, also there is no route, but what should I set the default route to.  On my old 515 Pix I used route 0.0.0.0 0.0.0.0 outside, but on this ASA (9.1.3) I can't set a default route to the outside interface or use the outside IP of the ASA as it is DHCP.
Packet trace
ciscoasa#  packet-tracer input inside icmp 192.168.0.10 8 8 4.2.2.2
Result:
input-interface: inside
input-status: up
input-line-status: up
Action: drop
Drop-reason: (no-route) No route to host
Super Bronze
I don't see why the ASA would not get an IP address from your ISP also.
In some recent 8.4 series softwares there were problems related to using the ASA as a DHCP Client.
So if you have a chance I would try and boot the ASA with a bit older software and see if that has any effect.
You wont have a route if your ASA has not even gotten an IP address from the ISP. It seems to me that the ISP Router is probably configured as bridged as you get a public IP address.
- Jouni
Silver
Enable
Config t
interface Vlan99
debug dhcpc detail
debug dhcpc event
debug dhcpc error
Re: Help with basic config for ASA 5505
Config t
interface Vlan99
Wow, it seems that worked!
Why though, please explain?
Why do I not need a default route?
Silver
I think I explained it on my previous post.
Without a default route you can not route to unknow networks, meaning nothing else other than your known networks that are you directly connected routes.
Thing is I don't have a default route and it all works, is something dynamic happening?
Why did the mac address method work?
Super Bronze
You have this configuration under the external interface
This means that your external interface will get the IP address from the ISP through DHCP and the "setroute" parameter means that the ASA will get the default route automatically from the ISP. So you wont need to configure a default route nor should you configure one when you are getting it from the ISP.
It seems that you have configured your laptops MAC address to the external interface of the ASA also.
I guess there might have been a problem with the fact that you had switched your firewall and laptop in the ISP router/modem and since your laptop worked just fine your ASAs external interface was configured with the same MAC address so that it would work also.
Typically I would think this might be an ARP related issue if you have switched 2 different devices (with different MAC address naturally) in the ISP Router/Modem but I am not sure if this is the case when you are using DHCP on your device but I guess it might be possible.
I have not run into a situation myself where the ISP would control what manufacturer device (determined from the MAC address) a customer would be able to use.
- Jouni
Silver
Are you running a "show run route" or "show route" to view if you have a route or not??
As you can see I didn't add a default route, but it has added one, I was looking on the ASDM and the routing section is empty.
ciscoasa# sh run route
ciscoasa#
ciscoasa# sh route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is 91.227.255.1 to network 0.0.0.0
C    91.227.255.0 255.255.255.0 is directly connected, outside
C    192.168.0.0 255.255.255.0 is directly connected, inside
d*   0.0.0.0 0.0.0.0 [1/0] via 92.237.255.1, outside
ciscoasa#
Super Bronze
- Jouni
Thanks, that makes sense to me know.
Also why did the mac address insertion fix my main issue on the outside interface? (whoops I see you replied to this already)
Message was edited by: Andy White
VIP Green
Before reloading the ASA, have you tried flapping the outside interface (shut, no shut)?
Please remember to rate and select a correct answer
-- Please remember to rate and select a correct answer
No luck with the "shut" "no shut" I'm afraid.  I will proceed with the debug and captures.
When I google Virgin Media and ASAs it seems it can be done, but like you say it could be a version issues too.  Will be back later with some more info, thanks guys.
Silver
Silver
Any other option would require troubleshooting and it could be related to layer 2.
Very detailed reply
Very detailed reply
1323
