Help with config
I have attached my config and took out the ip and password info. I am trying to setup a webserver and remote desktop connection on 3390 but the logs keep stating that incoming connections are being blocked the the inbound ACL. Can someone tell me what I have wrong please.
Thanks in advance.
Re: Help with config
William, I assume you have only one public IP address which is applied to your outside interface, if this is correct you want to do acl as follows.
Say this is your outside interface IP address 10.10.10.1
Add this to your access list, replace 10.10.10.0 with outside IP information.
access-list outside_int extended permit ip 10.10.10.0 255.255.255.0 interface outside
Jorge
That didn't seem to work. I am using PIX 8.02 and the error I get is "ERROR: IP address,mask doesnt pair". So I added this but it still is not working "access-list outside_int extended permit ip host xx.xxx.xx.x interface outside".
113
