Help with inside port of ASA 5520
I have an ASA 5520 and I'm using Solarwinds real time interface tool to monitor the through put of the port.  It seems I can never get it to use more than 100mb, where should I check?
I have run a sh int giga 0/1 and it shows the port is 1000mb full duplex and the I have also checked the other end where it plugs into the LAN and this also says the port is running at 1000mb full duplex.
Any ideas or are there any stress testing tools I can use?
1 REPLY
Re: Help with inside port of ASA 5520
To see 1000mbs what ever you are using, must understand 64bit counters. 100mbs is the max for 32bit counters.
Check your software vendor.
218
