Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Help with PAT, 5512-X, 8.6(1)2
I have a new ASA 5512-X hooked up to a Clear Router (set to passthrough) on the Outside and a Netgear switch on the Inside.
I can ping internet addresses from the ASA console but not from devices on the Inside. Looks like a PAT issue... or routing. Echos going out, replies not coming back in.
Packet Tracer says an ICMP echo outbound passes.....
What am I missing??
ciscoasa# show running-config
: Saved
ASA Version 8.6(1)2
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address dhcp setroute
interface GigabitEthernet0/1
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
nameif inside
security-level 50
ip address 10.200.0.1 255.255.255.0
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
same-security-traffic permit inter-interface
object network InternalNets
subnet 10.200.0.0 255.255.255.0
access-list inside_access_in extended permit ip any any
pager lines 24
logging enable
logging buffer-size 10000
logging asdm-buffer-size 512
logging monitor informational
logging buffered debugging
logging trap debugging
logging asdm debugging
logging rate-limit 1000 60 level 1
logging rate-limit 1000 60 level 6
mtu management 1500
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) dynamic interface
access-group inside_access_in in interface inside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 management
http 10.200.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd auto_config outside interface management
dhcpd enable management
dhcpd address 10.200.0.2-10.200.0.250 inside
dhcpd auto_config outside interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:4997430d9f627501b82040ce2bcb2a1b
: end
ciscoasa#
1 ACCEPTED SOLUTION
Super Bronze
Try adding
inspect icmp
inspect icmp error
Or use
fixup protocol icmp
fixup protocol icmp error
Both accomplish the same thing. The latter one is just the old format for the command which the ASA should still accept. Without these the ICMP through the firewall generally fails.
Hope this helps
- Jouni
1 REPLY
Super Bronze
Try adding
inspect icmp
inspect icmp error
Or use
fixup protocol icmp
Hope this helps
- Jouni
183
