Help with Port Forwarding from Outside Address
Can someone point me to info on port forwarding from an external address to an internal address. This firewall has a DMZ, but the machine I want to port forward to does not sit in the DMZ. All attempts to solve have lead to my machines in the DMZ not working.
Everyone's tags (2)
2 ACCEPTED SOLUTIONS
Re: Help with Port Forwarding from Outside Address
Be aware that an ACL must allow the traffic comes from Internet to DMZ servers.
Br,
Ok, have you already checked all ACLs for inside and outside directions?
Try this command below:
static (inside,outside) tcp 1.1.1.1 www 2.2.2.2 www netmask 255.255.255.255
where 1.1.1.1 = it is your public ip address and 2.2.2.2 it is your internal one ( RFC 1918 ). In this example, the firewall is performing a static PAT for HTTP service. In this case, the reachable ip address for the Internet will be 2.2.2.2
Br,
Sorry, the ip will be 1.1.1.1 to be reachable by Internet
So are you saying:
static (inside,outside) tcp External-IP www Internal-IP www netmask 255.255.255.255
That's correct.
Br
Thanks for the reply, but it didn't work.
Br,
Yes,  realize that. But, this is not a DMZ host, it is one that sits on the inside network.
Got it. I added:
access-list Inside_access_out extended permit tcp any host 192.168.14.252 eq www
access-list Inside_access_out extended permit tcp host 192.168.14.252 eq www any
and everything finally worked.
Thanks again for your help.
Chuck
You are welcome.
Best regards,
Renato Saraiva
1205
