High CPU due to packet capture
IF we do not remove packet capture on ASA does it cause CPU to spike?
Krishna
  • Firewalling
Still awaiting ur reply
whether a single src to single dst pcap or network ?
ideally not recommended to keep the pcap enabled, but still less impact on asa.
instead of you deciding pcap as a source of high cpu, it would be better to check whether its a cosmetic bug or genuine bug.
regards
Rajesh
There were 4 packet caps running on the device all were SRC to DEST.
How much CPU does each packet cap can take.
Krishna
Pls ask if you have some other queries. Only development team can answer to ur qsn.
Cpu was alright when captures were removed so just wanted to make sure it was due to that
Re:High CPU due to packet capture
Did we have circular buffer captures enabled ? Which asa device are you seeing this issue on ?
No. Circualr buffer was nt enabled, my question is once the buffer is full, will that lead to high CPU or not. The ASA is 5540
Hi Krishna,
We have seen this problem before on some TAC cases and we do have a Bug Defect for the same issue.
Although this Bug Defect is not resolved as we were not able to recreate the issue.
Thanks very much replying, so ideally it should be dropping the packets once the buffer is full.
Krishna
542
