High cpu load - burst traffic
I have high cpu load on ASA 5520, I'm supposing there is burst traffic (even though I do not have many interface overrun errors). How can I detect burst traffic ? I've tryied to use a netflow collector but I could configure on ASA a timeout rate of 1 minute and probably burst traffic is restricted to some milliseconds.
ps. throughput is quite low
Have you reviewed this link bellow  - referencing  the high  CPU session check list can  help isolate.
http://www.cisco.com/en/US/partner/products/hw/vpndevc/ps2030/products_tech_note09186a008009491c.shtml
Generally netflow in asa could still provide you with ingrees traffic giving some clues of high traffic utiliaziton but usually high CPU is cause by other factors,  review the link provided.
Thanks for your answer,
the link you provided doesn't work, maybe you were referring to
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a0080b8e100.shtml#CPU which I've already reviewed.
You sure burst traffic can't affect cpu load ? I really don't know what to search for, connections? inspection service policy? asp drops? intefaces throughput .. nothing has really much changed. Issue has started after I upgraded from 7.2 to 8.2. The only difference is basic threat detection which now is enabled but actually it doesn't impact cpu load at all.
Is the ASA running high on CPU constantly or do you see CPU spikes?
Can you post 'show tech' from ASA (hide the IP's if you want)?
What is the normal CPU usage on your ASA and how much is it using now?
I will review the output and let you know the next step.
Sourav Kakkar
212
