higher security level to low security level without NAT
Hi all, is it possible that the inside interface can access servers in DMZ with using NAT?
1 REPLY
Re: higher security level to low security level without NAT
You mean access the DMZ from inside network without nat ?
Sure you can ..
access-list no-nat permit ip 255.255.255.0
nat (inside) 0 access-list no-nat
I hope it helps .. please rate helpful posts !!!
103
