Hopelessly lost, again, re: NAT'ing with NAT control on
I am sadly lost, again, and need help.
Everything I thought I knew about NAT'ing seems completely backwards.
I am struggling to understand an existing config.
Here are the pertinent lines:
interface GigabitEthernet0/0
description ASA_NET_227.76.40.19/28
nameif Primary_Public
security-level 10
ip address 227.76.40.19 255.255.255.248 standby 227.76.40.20
nat-control
global (Primary_Public) 1 interface
static (Production,Primary_Public) 227.76.41.0 172.20.41.0 netmask 255.255.255.0
To me, as I understand it, the interface Primary_Public is the global interface = OUTSIDE interface.
But, breaking down the static NAT rule, I thought it was:
static (inside, outside) "inside address" "outside address" netmask 255.255.255.0, where we are mapping an entire subnet.
But this makes no sense to me. How can a public address like 227.76.41.0 be considered an "inside address"?
Especially when the interface Primary_Public is declared an outside interface, yet contains an IP address within the subnet that is now stated to be "inside" within the static nat rule.
Everyone's tags (5)
1 ACCEPTED SOLUTION
Hello Paul,
You are confused... ASA 8.2 or lower versions speaking the sintax is like this:
static (local interface, global interface) global_ip local_ip
That is the way the static's are build on an asa runing a version 8.2 or lower
Do rate all the helpful posts
Julio
Security Networking Engineer
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Hello Paul,
Julio
Thanks Julio.
The material I was looking at was clearly not accurate.
Hello Paul,
My pleasure to know I can help
365
