How can I stop telnet and ping Firewall from outside interface.
    Can anyone tell me, how can I stop telnet and ping Firewall, and only allow SSH from outside interface.   I am setting upp with Zone based Firewall in the router. Attached is config file
1 ACCEPTED SOLUTION
Re: How can I stop telnet and ping Firewall from outside interfa
Sorry , Here is the right link
https://supportforums.cisco.com/docs/DOC-34539
Remember to rate all of the helpful posts.
For this community that's as important as a thanks.
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Hello Sheng,
You mean traffic to the router managment plane right?
If this is the case you have 2 options:
A) Use the self-zone
B) Use an ACL on the outside interface and restrict Incoming traffic
Hi, Jcarvaja
   Thanks for replied my question. Yes, I want to block telnet and ping traffic from outside to access router
How do I use self-zone in the router.
Hello Sheng,
https://supportforums.cisco.com/docs/DOC-34531
The above link was not valid..
Not Found
The item does not exist. It may have been deleted
332
