You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our beta test area to get started.
How do block a range of ip's via PDM on PIX 501
I need to block a range of ip's, 123.8.0.0 to 123.15.255.255. How do I do that?
  • Firewalling
1 ACCEPTED SOLUTION
Re: How do block a range of ip's via PDM on PIX 501
That's correct. And I made a mistake because the PIX doesn't use inverted masks, so it would be:
123.8.0.0 255.248.0.0
John
HTH, John *** Please rate all useful posts ***
You can create an acl like:
access-list BLOCKED deny ip 123.8.0.0 0.7.255.255 any
This will cover you from 123.8.0.1 - 123.15.255.254.
HTH,
John
If i'm using the PDM I assume 123.8.0.0 would be the ip and 0.7.255.255 would be the mask. Is my assumption correct?
John
If, as per your subject, you want to do this via PDM, then you need to go to:
Configuration>Access Rules>Access Rules>Add
Looks like this screen:
http://www.netcraftsmen.net/welcher/papers/pdm-fig02.jpg
Then just add a rule as per the previous poster's reply.
162
