Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
How do i create site to site VPN with two ASA 5505s
I am fairly new to this forum, pretty new to cisco but I know I will get good help from here.
I have 2 pieces of ASA5505 and I want a site to site VPN for my network of two locations.Site A(HQ) and SiteB(branch)
The purpose is to access a server with local ip  10.1.50.201 in HQ from branch.I have two public ip addresses from ISP.
Can someone help me with all the configs that I need to get the VPN up and running.
Super Bronze
Your post doesnt yet contain all the needed information. (networks, IP addresses, ASA software levels)
Perhaps you can share the current configurations (with changed public IP addresses) with us so we can determine the needed configurations.
- Jouni
Result of the command: "show run"
: Saved
ASA Version 8.2(5)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address xxxx.xxxx.xxxx.xxxx 255.0.0.0
ftp mode passive
access-list outside_acl extended permit ip any any
access-list outside_1_cryptomap extended permit ip host 10.1.50.0 host 10.1.51.0
access-list inside_nat0_outbound extended permit ip host 10.1.50.0 host 10.1.51.0
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
access-group outside_acl in interface outside
route outside 10.1.50.0 255.255.255.0 xxxx.xxxx.xxxx.xxxx
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs group1
crypto map outside_map 1 set peer xxxx.xxxx.xxxx.xxxx
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.5-192.168.1.36 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
tunnel-group xxxx.xxxx.xxxx.xxxx type ipsec-l2l
tunnel-group xxxx.xxxx.xxxx.xxxx ipsec-attributes
pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:3a09a2e324dffbfa9b945aa0875dce8d
: end
I want to erase the above config.I just need someone to send to me  a working config.
remote network address: 10.1.51.0 mask 255.0.0.0
someone can mail me a good config: olaibigbami@yahoo.com
xxxx.xxxx.xxxx.xxxx
Super Bronze
Re: How do i create site to site VPN with two ASA 5505s
That is only one ASAs configuration.
But there are some clear problems there and with what you are asking.
  • Your "outside" interfaces mask is /8 = 255.0.0.0. I doubt that this is correct
  • Your NAT0 and VPN ACLs contain only single host addresses on each side. You should use a complete network.
  • Those same ACLs have a source address which isnt located on this ASA. You have local network 192.168.1.0/24 yet you use 10.1.x.x/yy addresses in the NAT0 and VPN ACLs as source
Majority of your configuration are correct but I would suggest correcting the networks and network masks in the configurations. After they are correct there should be no problem forming the L2L VPN connection. Naturally you have to make sure that the remote end doesnt have same problems.
- Jouni
I have factory-default so I can star over again.I'm not good with CLI so i use asdm for setup.
I would not mind if anyone send me a working config of site 2 site VPN on ASA 5505 so i can use.
All i need is for remote network 192.168.1.0/24 to connect to a server in HQ(10.1.50.0)
Other usersin HQ(10.1.50.0) should be able to connect to server- nothing more.
my configs for the two sites are shown below and VPN is not comming up:
: Saved
ASA Version 8.2(5)
hostname HQ
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
ftp mode passive
object-group network DM_INLINE_NETWORK_1
network-object host 10.1.50.0
network-object host 255.255.255.0
object-group network DM_INLINE_NETWORK_2
network-object host 192.168.1.0
access-list outside_1_cryptomap extended permit ip object-group DM_INLINE_NETWORK_1 object-group DM_INLINE_NETWORK_2
access-list inside_nat0_outbound extended permit ip object-group DM_INLINE_NETWORK_1 object-group DM_INLINE_NETWORK_2
pager lines 24
logging enable
mtu outside 1500
mtu inside 1500
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 x.x.x.x (HQ ip) 1
http server enable
crypto map outside_map 1 set peer x.x.x.x(branch ip)
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd enable inside
webvpn
tunnel-group x.x.x.x type ipsec-l2l
tunnel-group x.x.x.x ipsec-attributes
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
Cryptochecksum:4c56a2036a58f8637bb132a47347668e
: end
: Saved
ASA Version 8.2(5)
hostname Branch
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
access-list outside_1_cryptomap extended permit ip 192.168.1.0 255.255.255.0 object-group DM_INLINE_NETWORK_1
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 object-group DM_INLINE_NETWORK_1
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
arp timeout 14400
http server enable
crypto map outside_map 1 set peer x.x.x.x (HQ ip)
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd enable inside
webvpn
tunnel-group x.x.x.x (HQ ip) type ipsec-l2l
tunnel-group x.x.x.x (HQ ip) ipsec-attributes
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
Cryptochecksum:b38e9c7c9c055bd9aab301eea6d35c09
: end
Thanks for anticipated response.
Super Bronze
Both your NAT0 and VPN ACLs are wrong.
Both of your ASAs also have the same LAN network. Above it says HQ is 192.168.1.0/24?
You have to change the other devices LAN network to the correct one. You also have to change the ACLs I mentioned.
HQ
Add the new ones
access-list outside_1_cryptomap extended permit ip 10.1.50.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 10.1.50.0 255.255.255.0 192.168.1.0 255.255.255.0
Remove the old ones
no access-list outside_1_cryptomap extended permit ip object-group DM_INLINE_NETWORK_1 object-group DM_INLINE_NETWORK_2
no access-list inside_nat0_outbound extended permit ip object-group DM_INLINE_NETWORK_1 object-group DM_INLINE_NETWORK_2
BRANCH
Add the new ones
access-list outside_1_cryptomap extended permit ip 192.168.1.0 255.255.255.0 10.1.50.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 10.1.50.0 255.255.255.0
Remove the old ones
no access-list outside_1_cryptomap extended permit ip 192.168.1.0 255.255.255.0 object-group DM_INLINE_NETWORK_1
no access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 object-group DM_INLINE_NETWORK_1
Also it seems that both of your ASAs are using DHCP for their "outside" interface? How are you going to keep the L2L VPN up for the 2 end points if they dont have a static public IP address?
Or does the ISP assing the same public IP address based on the device MAC address?
- Jouni
Thank you.
I have made the changes you recommended but both ASAs are still not forming VPN connection.
They are both tearing down TCP & UDP connections and translations to  & from outside.They are also denying incoming TCP.
The ISP gave me two public ip addresses.My modem is in bridge mode so the modems delivers public ip addresses to my WAN interfaces.
What else could be tearing down connections & translations? Please, help urgently.
Hello try this , this is detail step by step configuration ,
http://www.youtube.com/watch?v=lGbsQJOxjsI
Re:How do i create site to site VPN with two ASA 5505s
Sounds like you need to tell the ASA not to your internal networks that are traversing the VPN tunnel.
There is a Cisco config guide for this.
This is also dependant on which IOS version you are running
Sent from Cisco Technical Support Android App
-- CCNP, CCIP, CCDP, CCNA: Security/Wireless Blog: http://ccie-or-null.net/
You ASDM. Cisco ASA is well known for its ASDM easy to configure everything.
Jawad
Jawad
1141
