Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
How do I forward a port?
I'm very new with cisco routers, so sorry if this is a dumb/extreamly easy question. I want to forward traffic on port 5950 to an internal ip address (10.11.100.10) on that same port. How would I go about doing that (preferably via CCP)? Thanks.
1 ACCEPTED SOLUTION
Re: How do I forward a port?
I would suggest following "scenario 4" under "Static Address Translation Scenarios" in http://www1.cisco.com/en/US/docs/net_mgmt/cisco_configuration_professional/v2_3/olh/ccp/ccp.pdf
It should be straightforwards.
I hope it helps.
PK
I hope it helps.
PK
Take a look at this link: http://www.cisco.com/en/US/products/ps9422/products_configuration_example09186a0080b2f103.shtml#nat1
Follow the static NAT configuration. It has nice screen shots.
-KS
Community Member
That was pretty simple and straight forward. Thanks.
316
