Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
How do I upgrade PIX525(Ac+FO)6.3 to 8.0
Hello Pro,
I plan to upgrade two PIX525(Active/FO mode) 6.3 to 8.0 The current flash:16M,memory:256M.
I'd like to know the followings:
1. Do I need to upgrade flash and memory card;
2. How do I get ur license and fo license
3. May I upgrade from 6.3 to 8.0 directly, or I need to upgrade to middle version 7.x at first and then proceed to 8.0
It's an upcoming issue, would you please give me some advice on this issue?
Thank you!
Re: How do I upgrade PIX525(Ac+FO)6.3 to 8.0
Le, go over bellow links to get you started on assesment,all your questions are answered there ...
No , you seem to meet requirements, 16F and 256RAM minimum is required for ur and fo.
Whatever active license is running under 6.x will carry over onto 7.x/8.x
my suggestion is to upgrade to a GD release in the 7.x train first.
http://www.cisco.com/en/US/docs/security/asa/asa70/pix_upgrade/upgrade/guide/pixupgrd.html
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00804708d8.shtml
maybe this one is usefull to you:
http://www.cisco.com/en/US/docs/security/pix/pix80/release/notes/prn803.html
Johan
137
