Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
how i connect two link on one interface of ASA 5540
hello,
i have asa 5540 in which i want to connect two link on intranet interface. and i have only one interface.
and also tell me that two link how i terminate in one link. both link is on different IP.
i seen that if i do sub interface then its work , is it true in simple mode of firewall.
1 REPLY
Re: how i connect two link on one interface of ASA 5540
Mitang,
It is correct what you have read.
Simply configure subinterfaces which will use dot1q trunk. If you have one physical terminate that physical interface into your L2 switch, create the vlans in switch and associate them with asa logical subinterfaces with respective vlans, in other words if you have one phycal interface left, you can split that phisycal into many logical vlans interfaces,your asa5540 can support up to 200 Virtual LANs so you have plenty to work with.
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/intrface.html
123
