Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Bronze
how to access cisco home lab remotely?
hi every body!
I have this issue:
my cisco lab is (6 routers and 2 switches) are connected to access server(2509)
i want to connect to my lab remotely. I want to telnet into access server then connect to routers,switches etc.
My problem is i am using link system switch which is connected to dsl modem for internet access,link system performing nat, allowing my computer and my mom computer to access internet simulatanously. If i connect access server( 2509) to one of port of link system switch, link system will assign the 2501 a private ip address.
Obvioulsy, i cant use this private address to telnet into access server.
Is there any way , i can telnet into 2501 server in this situation?
thanks alot !
1 ACCEPTED SOLUTION
Re: how to access cisco home lab remotely?
This is how I used to do,
- I have a Linux box with two interfaces.
eth0 - connected to my access server
eth1 - connected to my broadband router
- broadband router (Linksys W54G) - which allows me to configure port redirection to my Linux box eth1.
I configured by DSL modem in bridge mode and the Linksys W54G router to connect over pppoe.
So the public IP is assigned on the Linksys box.
myLaptop on Internet ->>> (SSH)- >>>((LinksysBox-publicIP)) >> forwarded to myLinuxBox on eth1 on port 22.
Now once I login into myLinux box I telnet into on the access server and work on my Cisco rack.
There are benefits of using the Linux box as I can restrict SSH to limited IP, allow/deny ip/ports using the IPtables FW also.
Hope this helps.
Dhananjoy
Hope this helps.
Dhananjoy
Community Member
Hi ,
Just contact with you ISP provider and configure the terminal server to connect your Router and Switches then use some terminal connect softwares then you can connect.
Shridhar
300
