Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
how to adjust non_tcp_udp timeout on FWSM
Because I want to change the "GRE" protocol timeout value , on the FWSM Command Reference 3.1,
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/mod_icn/fwsm/fwsm_3_1/fwsm_ref/t.htm#wp1259027
I find the "non_tcp_udp" syntax on the web, but I cannot adjust this value on FWSM,how can I
adjust this value?
regards
Amber
Community Member
Re: how to adjust non_tcp_udp timeout on FWSM
To set the maximum idle time duration, use the timeout command in global configuration mode timeout {xlate | conn | half-closed | udp | icmp | h225 | h323 | mgcp | mgcp-pat | sip | sip_media | non_tcp_udp | sunrpc | uauth.Refer URL
Community Member
I known the "timeout" command , but the "non_tcp_udp" parameter is not exist on fwsm even though you can find "non_tcp_udp" on CCO documentation.
Amber
241
