How to allow SSH into Zone Based Firewall?
I am stuck in trying to figure out on how to allow a ssh connection from the outside to the wan uplink on my firwall. I just recently converted to the zone based. I have tried adding all different types of ways but no luck. Can someone help me out?
Let's say I wanted to configure a specific ip address from the internet to access the router only thru ssh.
Re: How to allow SSH into Zone Based Firewall?
Hi MANNY,
Just add commands I provided.
class-map type inspect match-all SSH
match protocol ssh
policy-map type inspect sdm-permit
class type inspect SSH
inspect
You may filter hosts to access this device by adding ACLs into into the class-map.
Please let us know how things work out.
HTH,
Toshi
Hi Toshi,
First of all thanks for your suggestions. I tried what you suggested but got an error. Here is the exact copy from the router. Since it did not like the inspect command I tried pass but that did not work either. Any other suggestions?
Manny-2691(config)#class-map type inspect match-all SSH
Manny-2691(config-cmap)#match protocol ssh
Manny-2691(config-cmap)#!
Manny-2691(config-cmap)#policy-map type inspect sdm-permit
Manny-2691(config-pmap)#class type inspect SSH
Manny-2691(config-pmap-c)#inspect
%Protocol ssh configured in class-map SSH cannot be configured for the self zone. Please remove the protocol and retry
Hi Manny,
Sorry That was my fault. It should be like this.
Manny-2691(config-pmap-c)#pass
HTH,
Toshi
Hi Toshi,
The pass did not work either. Here is what I have in the config so far. I have attached a snapshot from SDM to see if it makes any sense.
Thanks for your help by the way. I am currently studying for my CCNA Security and is bugging the heck out of me.
class-map type inspect match-all sdm-cls-VPNOutsideToInside-1
match access-group 103
class-map type inspect match-any SDM_AH
match access-group name SDM_AH
class-map type inspect match-any sdm-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol h323
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp extended
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all sdm-insp-traffic
match class-map sdm-cls-insp-traffic
class-map type inspect match-any SDM_ESP
match access-group name SDM_ESP
class-map type inspect match-any SDM_VPN_TRAFFIC
match protocol isakmp
match protocol ipsec-msft
match class-map SDM_AH
match class-map SDM_ESP
class-map type inspect match-all SDM_VPN_PT
match access-group 102
match class-map SDM_VPN_TRAFFIC
class-map type inspect match-any SDM-Voice-permit
match protocol h323
match protocol skinny
match protocol sip
match protocol h323
class-map type inspect match-any sdm-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
match protocol ssh
class-map type inspect match-all GRE
match access-group 104
class-map type inspect match-all sdm-icmp-access
match class-map sdm-cls-icmp-access
class-map type inspect match-all sdm-invalid-src
match access-group 101
class-map type inspect match-all sdm-protocol-http
match protocol http
policy-map type inspect sdm-permit-icmpreply
class type inspect sdm-icmp-access
inspect
class type inspect SDM-Voice
inspect
class class-default
pass
policy-map type inspect sdm-pol-VPNOutsideToInside-1
class type inspect sdm-cls-VPNOutsideToInside-1
inspect
class type inspect GRE
pass
class class-default
policy-map type inspect sdm-inspect
class type inspect sdm-invalid-src
drop log
class type inspect sdm-insp-traffic
inspect
class type inspect sdm-protocol-http
inspect
class type inspect SDM-Voice-permit
inspect
class class-default
pass
class type inspect SDM_VPN_PT
pass
inspect
pass
class class-default
drop log
zone security out-zone
zone security in-zone
zone-pair security sdm-zp-self-out source self destination out-zone
service-policy type inspect sdm-permit-icmpreply
zone-pair security sdm-zp-VPNOutsideToInside-1 source out-zone destination in-zone
service-policy type inspect sdm-pol-VPNOutsideToInside-1
zone-pair security sdm-zp-out-self source out-zone destination self
zone-pair security sdm-zp-in-out source in-zone destination out-zone
service-policy type inspect sdm-inspect
Hi Manny,
When you are trying to do SSH to the router then what's the exact error you got?
Edit: What is the exact ip address you are trying to use as a source ip address to do ssh to the router?
access-list 105 remark VTY Access-class list
access-list 105 remark SDM_ACL Category=1
access-list 105 permit ip 10.1.1.0 0.0.0.255 any
access-list 105 permit ip 192.168.2.0 0.0.0.255 any
For testing :
line vty 0 4
No access-class 105 in
Please let me know.
Toshi
I got the error below when I tried putting the inspect command on the router under the policy-map. It did not like the inspect, so I tried the pass but that is still not letting me ssh into the router from a remote ip address. Here was the error.
%Protocol ssh configured in class-map SSH cannot be configured for the self zone. Please remove the protocol and retry.
Manny,
Well, It has to be "PASS".
What's the exact source ip address you are trying to do ssh to the router?
Let's see my previous post
Toshi
Ok here is the updated config. I have list the source IP in the access-list 105 for the VTY. It starts off with 99.xxxx.
Manny,
Without using Zone Base Firewall. Did you ever access the router by using SSH protocol? I've not seen any crypto key generated by the router.
Pleas let me know
Toshi
Toshi,
Yes, I have verified that the crypto keys are generate using the command "sh crypto key mypubkey rsa" or using the SDM. I have not been able to SSH using this configuration. If I use a simple config from scratch, I can. But when I start adding all the policys and class maps that's when I can't get back in.
Many,
Here is my last hope. let's try this first
no class type inspect SSH
ip access-list extended SSH
permit tcp any any eq 22
class-map type inspect match-any SSH
match access-group name SDM_SSH
pass
OR
match access-group name SSH
class-map type inspect match-any access-to-router
match class-map SSH
class type inspect access-to-router
inspect
Toshi
Toshi! You are a genius dude! The second option worked beautifully! I really appreciate your help.
Is there a book/resource that you used to learn this? I am going thu my CCNA security exam and it doesn't go to much into detail on Zone firewalls. I did buy the Cisco Deploying Zone-Based Firewalls book, but did not show an example of ssh access.
Now all that is left is allowing webserver/mail/ftp. Do you have any quick examples of that?
Thank again.
Manny
Manny,
Please check this link out. It may helps you.
http://www.cisco.com/en/US/products/sw/secursw/ps1018/prod_white_papers_list.html
I'm now sleepy head. (grin)@4am.
Toshi
Thanks again!
Does this also count for snmp because it seems that snmp is also blocked by default
Hi Fred,
I guess it depends if your using snmp in the inside or outside?
I'm trying to get it working from the outside. I wasn't able to connect with the Cisco 871 from the outside with ssh but that is functioning know due to your solution. I was wondering if this also the case with monitoring from the outside because we want to monitor customers remotely.
I will try it later on tonight and let you know. I am fairly new to Zone-Based Firewalls. I would think to follow the same concept of ssh as in th example above. Post your config and maybe Toshi can comment on it.
here is my config;
Hi Fred,
Outside zone to self has a class-default that denies everything there by default. Yes! we can change it. You need to configure what you want to allow on your policy-map(sdm-permit). It can be either "Inspect" or "Pass" when using ACL to match traffic you want. Keep in mind when using a "PASS" keyword you then need to allow from self to Outside zone as well. That's why we prefer "Inspect" as we did before.
HTH,
Toshi
Hi Toshi,
Should i then also alter the next;
match class-map SSH
inspect
class class-default
it is not clear to me what to configure.
Hi All
I had exactly the same issue with enabling just SSH accesss to the router for remote control.
Only passing ssh traffic worked, inspecting would not work at all ...because of the following error :
%Protocol ssh configured in class-map classSSH cannot be configured for the self  zone. Please remove the protocol and retry
we are talking about such a policy:
Policy Map type inspect policyOutsideToRouter
     Description: policy allowing  remote access to router
          Class classSSH
               Inspect
     Class class-default
     Drop  log
Can someone please explain why ssh traffic coming from WAN to self zone cannot be inspected, why it has to be passed ??
Andrzej
3483
