How to avoid swap of ASA Management IP addresses in case of failover ?
We have 2 ASA 5525X V9.1.2 in active/passive failover mode; they are managed via their M0/0 interface
Is there a way to avoid that primary and secondary ASAs exchange their own IP addresses at time of failover ?
the objective is to allow each ASA to be always managed via the same IP address whatever their active/standby state ;
the "no monitor management" command only allows to avoid a failover to occur in case of failure of the management interface of the active ASA;
thank in advance for any help
Hi,No  , this will not be
No  , this will not be possible. This is because every component of the configuration will  be replicated.
Thanks and Regards,
Vibhor Amrodia
ok, it's a pity ;thanks for
ok, it's a pity ;
thanks for you answer
62
