Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
how to block teamviewer remote desktop
Dear all,
how to block teamviewer remote desktop on cisco ASA5550.
prompt response is much appicate.
thanks & regards
Re: how to block teamviewer remote desktop
Since teamviewer seems to use outbound port 80 (http) for the communication channel, effectively blocking it will be somewhat complex. The best way I can think to accomplish this would be to define custom regex to match the identified traffic and then use a class-map to block it.
This Cisco article describes the process:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080940e04.shtml
Hope this helps.
Could you please try the following conf.in your ASA to block teamviewer .
http-map inbound_http
port-misuse p2p action drop log
port-misuse tunneling action drop log
class-map http-port
match port tcp eq www
policy-map inbound_policy
class http-port
inspect http inbound_http
service-policy inbound_policy interface inside
Hope this helps
many thanks for all your efforts,
i will try and show the result, meanwhile, some other software similiar to teamview, like logmeon, securelogin, Timbuktu Pro, can also protect from the above statements.
thanks in advance,
Could you block team viewer with that conf. Otherwise we can try some other way
Jithesh
1900
