HOW to block websites
Dear  all,
I am using 1841 router(Version 12.4(13r)T) and configured as a ZBF as follwos,as you all have told me.My idea is to block unwanted sites like facebook.This router is not yet connected.
Current configuration : 1076 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
parameter-map type regex DENY_SITES
pattern .*facebook.com
archive
log config
  hidekeys
class-map type inspect http match-all CLASS_DENY_SITES
match  request header host regex DENY_SITES
policy-map type inspect http POLICY_DENY_SITES
class type inspect http CLASS_DENY_SITES
  reset
class class-default
zone security INSIDE
zone security OUTSIDE
zone-pair security IN_OUT source INSIDE destination OUTSIDE
interface FastEthernet0/0
no ip address
zone-member security INSIDE
duplex auto
speed auto
interface FastEthernet0/1
no ip address
zone-member security OUTSIDE
duplex auto
speed auto
ip forward-protocol nd
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
But when I try to apply policy on zoon-pair,I am getting the following error.
Router(config-sec-zone-pair)#service-policy type inspect POLICY_DENY_SITES
Inspect service-policy attachment failed
Why it is not allow to apply policies.Pls help me at your earliest....
Thank you
3 ACCEPTED SOLUTIONS
Re: HOW to block websites
No problem
It does supported but you cannot apply it directly to the Service-Policy
  reset
class-map type inspect HTTP_123
match protocol HTTP
policy-map type inspect HTTP_123
class HTTP_123
inspect
service-policy POLICY_DENY_SITES
service-policy type inspect HTTP_123
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Yeah
I just updated the previous post!
Jcarvaja
No,
That's the only method available to block HTTP websites using the local database, otherwise you should get a content engine.
You sure the site is not being switched  to HTTPS? try with a different site (Youtube for example or anyone that commes into ur mind)
Note: Share the latest config please
Jcarvaja
As already answer you personally the problem is you are attaching a L7 policy to the service-policy.
Only L4 policies are supported on the service-policy.
What to do :
Create a L4 policy, set the L7 into that L4 and then attached the L4 into the service-policy
Jcarvaja
Highly appriciate your answer...thank you very much...
You mean ZBFW doesn't support L7 policies???
Could yu kindly show me how to do this...very sorry for my poor undersatnding...
No problem
  reset
match protocol HTTP
class HTTP_123
inspect
Jcarvaja
Thank you very much for the reply.
I have done the configuration as you have instructed.But I am still getting the same message.
class HTTP_123
inspect
Should it be as follows????
Router(config-sec-zone-pair)#service-policy type inspect HTTP_123 ???????
Yeah
Jcarvaja
Thank you verymuch for your help.I will apply this in the production env and check.Hope i can block unwanted sites in same manner.So I appriciate your quick response and rated....
Have good day
It is a pleasure to help,
Jcarvaja
I have tried to block facebook today in the same way i have mentioned above .But didn't workout.That means regex  method doesn't work???Can you give me anyother method??
Is the traffic going via HTTP or HTTPS, cause remember HTTPs cannot be blocked with this method as traffic goes encrypted.
Jcarvaja
HI,
Tried http trffick aslo,but didn't work.What is the other method you can recomend me?acces-list??
(ZBFW-inside inteface connected to the TMG server.outside--ISP,can't block frm the TMG atleast??)
No,
Jcarvaja
Yes you are correct...this is switching to https..
But my question is I just tried to block yahoo.com in this manner..didn't work.
You mean if it is https...we can't block  using even ASA????
No, it will not work because we are matching the header host value on the packet and with HTTPs that goes encrypted and the device will not be able to understand it.
Now with an ASA I have match the DNS requests looking for facebook.com so I block the DNS request, with no Resolution I will not be able to go to facebook unless I know the IP address which is highly unlekilly but at sometime it could happen.
Jcarvaja
Thx Julio....
So colclusion is ..if it is https...it is not able to block from ZBFW??But if it is http..can block in the above manner??
Pls corret me if I am wrong..
You got it
If you try to match an HTTP header host then you will block the traffic only if you are able to see what it says on that field
Http yes, u should
Jcarvaja
293
