Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
How to block yahoo messanger on LAN using ASA 5510 ?
Hello Everyone,
I want to block my LAN Users from accessing IM websites such as yahoo messanger,Gtalk etc. & facebook also.
Can anyone tell me how can i do that ?
Re: How to block yahoo messanger on LAN using ASA 5510 ?
This link should help you:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00808c38a6.shtml
Basically we will need to do all of this using MPF, Regex and http (deep packet) inspection. Let me know if this helps!!
Prapanch
Keep in mind the following:
a) if your messengers are getting tunneled or encapsulated over port 443 then there is no way to block it, inspect IM only deals with native msn/yahoo msngr packets but if its encap'd over http than inspect http will be used
b)Inspect IM supports MSN Messenger 7.0 (Build 7.0.0816), Yahoo Messenger 7.0.0.437.
This was tested by one of our colleague Kureli, and it worked for MSN
Try this for MSN:
regex msn-messenger "^VER [1-9] MSNP[1-9]+.*\x0d\x0a.*MSNMSGR.*\x0d\x0a"
class-map type inspect http match-all http-msn
match request method post
match request body regex msn-messenger
policy-map type inspect http http-msn
class http-msn      reset log
policy-map global_policy
class inspection_default
Note that there is a space between VER and [1-9], and [1-9] and MSNP
985
