how to check complete show run configuration and packet flow from outside to inside
Hi Team,
I have a concern with reference to know about the command to show all running configuration in multiple-context mode with single command.
Please also elobarate the difference between the packet flow from inside to outside and outside to inside.
generally first it looks for route flow then access-list. I am bit confused here what is the correct difference to flow of packets from out to in and in to out.
Thanks..
Silver
Can you explaint more exactly what do you mean, you are asking about difference in output and input lists, or how router process ACLs when it goes from input interface to ouput interface(Router will check both rules)?
Posted by WebUser Aleksandr Yanovskiy
We are talking about here packet flow on Firewall from out to in and in to out.
and a command to check complete running configuration for all context.
Hi Cisco Team,
Can you please confirm is there any such command....I am desperately looking for your help.
you can check the packet flow using "packet-tracer"
packet-tracer input outside tcp 1.1.1.1 1055 2.2.2.2 443
Dan
1332
