how to configure a NAT port range on ASA 5510
                  hi,
i have a cisco asa 5510 and would like to add a NAT rule for a range of ports like 50000-59999
Everyone's tags (3)
Re: how to configure a NAT port range on ASA 5510
Hmm is there any other way of doing this?
Red
Hi Dino,
what version are you using? It should be possible with 8.3 or higher codes.
Varun Rao
Security Team,
Cisco TAC
Thanks, Varun Rao Security Team, Cisco TAC
I'm using 8.4. How do I do it?
Red
Hi Dino,
Plz explain your requirement first.
Varun Rao
Security Team,
Cisco TAC
Ok I have rtp udp ports 50000 - 59999 to be nat from public to my private Lync server.
Red
Hi Dino,
You need to configure something like this:
object service udp_ports
  service tcp destination range 50000 50009
nat (outside,inside) source static any any destination static public_ip private_ip service udp_ports udp_ports
Hope that helps.
Varun Rao
Security Team,
Cisco TAC
Hi varun
Ok I did do the first part but couldn't do the second through asdm. I will try through cli.
Will try it tonight.
Red
Sure, let me know how it goes
Varun Rao
Security Team,
Cisco TAC
I am using ASA 8.2(5) 5505
I am using ASA 8.2(5) 5505 and wants UDP ports forwarding range 36,000 to 59,999.
please advise which commands to config and apply.
thank you a lot.
Hi Rizwan,
Hi Rizwan,
We can not create static NAT for range of ports in 8.2 version, Need to write multiple Statements or perform a Static one-to-one NAT.. This can be done in versions above 8.3 where there is change in the configuration of the NAT.
Please refer "Static NAT for a Range of Ports" section
https://supportforums.cisco.com/document/33921/asa-pre-83-83-nat-configuration-examples
You can create a static NAT in 8.2 and permit only the set of ports using the access list to allow it.
For example
static (inside,outside) <public IP> <Private IP> netmask 255.255.255.255
Now create access list for thsi traffic.
access-list outside_in extended permit udp any host <public IP> range 36000 59999
access-group outside_in in interface outside
Or you can upgrade the device to version above 8.3.
Shivapramod M
Please remember to select a correct answer and rate helpful posts
Hi Shivapramod,
Hi Shivapramod,
Thank you for the reply.
I will definitely upgrade to 8.3 or above to support range command because i can't add long list of commands in ASA.
Please advise commands for 8.3 or above to define UDP port ranges.
thank you so much.
Please refer the document which was mentioned in the last comment.
Please remember to rate helpful posts
I tried to enter the service group but it didn’t like destination.. is it a command that came later in IOS? I have version Cisco Adaptive Security Appliance Software Version 8.2(5) , Device Manager Version 6.4(5)
SA01(config)# object service Lync_RTP_UDP
ASA01(config-service)# service udp destination range 50000 50009
ERROR: % Invalid input detected at '^' marker.
ASA01(config-service)# object service Lync_RTP_TCP
ASA01(config-service)# service tcp destination range 50000 50009
Dino Chirico | IT Manager
T: 03 9697 2222 | F: 03 9697 2200 | M: +61 (407) 454600
W: Prosum.com.au | E: Dino.Chirico@prosum.com.au
A: 6 Ross Street , South Melbourne 3205
Disclaimer
This message may contain confidential, proprietary or legally privileged information and is intended only for the individual named. No confidentiality or privilege is waived or lost by mistaken transmission. If you are not the named addressee you should not disseminate, distribute, copy or disclose its contents to anyone. Please notify the sender immediately by e-mail if you have received this e-mail in error and delete all copies and destroy any hard copies from your system. PABX Sales and Service Pty Ltd Trading as Prosum of 6 Ross Street South Melbourne ABN 53 087 133 702 and any of its subsidiaries each reserve the right to monitor all e-mail communications through its networks. Any views expressed in this message are those of the individual sender, except where the message states otherwise and the sender is authorized to state them to be the views of any such entity.
I ended up doing this
object-group service Lync_RTP_UDP
service-object udp range 50000 59999
object-group service Lync_RTP_TCP
service-object tcp range 50000 59999
but I still can’t do the static nat
static (Lync_Ext,Internet_AAPT) udp x.x.x.x then I can’t refer to Lync_RTP_UDP
any other ideas?
thanks
Disclaimer
Red
Hi Dino,
Earlier you had provided that you are using the ASA software 8.4, so i suggested you the configuration for 8.4 version.
But now it seems like you are using 8.2 version. Unfortunately port forwarding for a complete range woudl not work in 8.2 version.
Varun Rao
Security Team,
Cisco TAC
Ok I will do an upgrade.. are there any gotchas or can I upload to the latest version?
thanks
Disclaimer
Red
Hi Dino,
Yes, there definitely are a few, since its a major upgrade to version 8.3 or higher. You can read through  this doc first, before upgrading, this is all need to know before the upgrade procedure:
https://supportforums.cisco.com/docs/DOC-12690
Varun Rao
Security Team,
Cisco TAC
This document will be ok if I’m coming from 8.2?
Disclaimer
thanks
Disclaimer
4948
