01-12-2010 05:59 AM - edited 03-11-2019 09:56 AM
Hello. We have a ASA 5520 and we have all kinds of trouble on our ftp connections. FTP servers disconnect immediately when we issue a data connection like "dir" or "get". FTP client is in the inside from a Windows Command line. Windows ftp does not really support passive mode. If we use a perl script, the data transfer will complete. What can we configure the ASA so that active mode is possible? Or, how can we configure the ASA so that there is no port translation will occur? Thanks in advance.
Solved! Go to Solution.
01-12-2010 06:11 AM
Try adding the FTP inspect to your policy. Here is a link for it.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807ee585.shtml
policy-map global_policy
class inspection_default
inspect ftp
01-12-2010 06:11 AM
inspect ftp
01-12-2010 02:16 PM
Thank you! That did it. We can now use ftp from Windows command line.
