How to copy contents of ASA 5510 to another ASA 5510?
I want to copy contents of 1 ASA 5510 to another 5510.
Both ASA has same license.
-I tried to connect to 2nd ASA via console cable
-Went to "Conf t" and copied config of 1st ASA. [ using paste tab from Hyper Terminal ]
- used commands like copy running config disk0:/startup.config.cfg
- also used write memory all , wr mem commands
- But after reboot config was gone.
As of now I have ASA 8.3.x version in both ASA's.
How can I save config to 2nd ASA via Hyper Terminal?
It would be easist if you used ASDM and did a full backup then restore it to the second ASA. That would copy everything including any certificates, custom profiles, AnyConnect clients, etc.
I am trying to save basic config.
Basic config also not getting saved.
Steps followed as follows :-
- Given private IP to eth 0/1
- no shut
- speed auto
- wr
- exit
- wr
- exit
- hostname asasec
- wr
- reload
After reload firewall is not saving configuration.
Re: How to copy contents of ASA 5510 to another ASA 5510?
Kindly post 'show version' output. Make sure the config register is 0x1.
Issue a 'no configuration-register' command if it's not.
204
