Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
How to do Failover using ASA 5505 ?
Hello All,
I am having Cisco ASA 5505 firewall. i am having 2 ISP connections. I wanna connect both links to firewall.
Is it possible to do failover & Load Balancing Using ASA 5505 ??
If it is possible then How to do that ?
Please guide me ....
Thanks.
Re: How to do Failover using ASA 5505 ?
Hi Vinayak,
Please find the link below. You might find it useful
https://supportforums.cisco.com/docs/DOC-13015
Namit
Community Member
Hi Namit,
I dont have any router in my network.
I want to connect both links on firewall itself. & i am Having ASA 5505.
Is LOAD BALANCING Possible on 5505 ???
Community Member
Hello CAN ANYONE HELP ME ????????
Vinayak,
Did you read this link https://supportforums.cisco.com/docs/DOC-13015
that was provided to your earlier?
It clearly says that the ASA CANNOT do load balancing between two diff. ISPs and also provides some alternatives.
If you do not have a router then, you can choose the option to do redundant config using SLA route tracking. Which means you will only use the backup ISP when the primary ISP fails.  That is your only other option without a layer3 device on the outside.
-KS
1389
