How to enable AES-CTR encryption for ASA 5520
Dear Team ,
           When we see the show ssh sessions on our ASA . it shows output as following
K-ASA# show ssh sessions
SID Client IP       Version Mode Encryption    Hmac     State            Username
0   x.x.x.x               2.0     IN      aes256-cbc      sha1     SessionStarted   *******
                                     OUT   aes256-cbc       sha1     SessionStarted   *******
We can observe that in encryption it is using aes256-cbc . Now we want to disable the cbc encryption and enable the CTR encryption for SSH .
For the same we have upgraded the asa OS to 9.1.2 . Kindly confirm how can we enable the same .
Rgds,
Tushar
Tushar,
It's eabled on the server.
MInd that you need the clien to want to use it :-)
From linux I tested this
ssh -c aes128-ctr bsns-asa5585-60-2 -l cisco
which resulted with
BSNS-ASA5585-60-2# show ssh sessions detail
SSH Session ID          : 1
Client IP              : 10.48.93.4
Username               : cisco
SSH Version            : 2.0
State                  : KeysExchanged
Inbound Statistics
  Encryption            : aes128-ctr
  HMAC                  : md5
  Bytes Received        : 272
Outbound Statistics
  HMAC                  : md5
  Bytes Transmitted     : 176
Rekey Information
  Time Remaining (sec)  : 3284
  Data Remaining (bytes): 996147024
  Last Rekey            : 09:00:43.255 UTC Tue Jan 21 2014
  Data-Based Rekeys     : 0
  Time-Based Rekeys     : 0
BSNS-ASA5585-60-2#
No special settings on ASA.
M.
Thanks a lot . Can u please confirm how we can test the same through putty . Or is there any other client through which we can test this ( through windows machine )
  How we can test this ( through which machine have u tested )  .. Also is there any way by which we can disable CBC encryption  on ASA 5520
Awaiting your reverts .
Rgds,
Tushar
  I just want to know if we can disable to CBC on ASA . I have got the ssh client which supports AES-CTR encryption .
We have one other ASA observation after VA test i.e SSH Weak MAC Algorithms Enabled .
Could u please help me in getting this closed ?
Rgds,
Tushar
859
