Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
How to Filter logs for particular ZONE on ASDM for FWSM
We recently deployed FWSM in our Data center & moved different VLANs behind the different zone.
For some zones we got the policy from the server administrator & we restricted that zone based on that but for some zone we couldn't able to get any
policy from server adminsitrator. The only thing we can do is to check the logs.
I can able to filter the logs but if i need to filter the particular zone log then how can i do it?
In main logging page i can see logging for all the zones.
Kindly provide the link if someone has for this.
Thanks.
Yasir
1 REPLY
Hi Yasir,
The best solution would be to view the logs in the Real-Time Log Viewer (Monitoring > Logging > Real-Time Log Viewer). From here, you can use the zone/interface name as a filter (i.e. "inside" or "outside"). This will allow you to only view logs for traffic that is traversing that interface.
-Mike
280
