Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
how to fix below problem on log
greeting
I have log:
Sep 10 03:19:37 [10.4.3.20.2.2] %ASA-6-106015: Deny TCP (no connection) from 10
.15.6.164/6389 to 10.4.27.102/4486 flags ACK on interface inside
Is it any possible to open firewall to allow this traffic pass? I believe, it is default settings on my asa5520.
Any comments will be appreciated
Thanks in advance
Community Member
Re: how to fix below problem on log
by the way, it seems on server side, there is no such traffice can be monitored.
so, what is the messages means?
any advice?
This is normal activity for a Firewall, if you check the system massages guide it explains the situation
http://www.cisco.com/en/US/docs/security/asa/asa72/system/message/logmsgs.html#wp1279822
236
