Bronze
How to Save Command Output to Flash on ASA 8.4
I nice easy one for you guys.
How do you save the command output from the CLI  to a file on flash?
With IOS, I would normally use a pipe command to redirect to tftp, but the ASA doesn't support this as far as I can tell. As a work around I was thinking I could save the output to flash and then tftp that file off the ASA.
Paul
HTH Paul ****Please rate useful posts****
Everyone's tags (4)
2 ACCEPTED SOLUTIONS
Super Bronze
Easier solution for you - just use the telnet/ssh client logging feature to save the output of ASA command to a text file.
Super Bronze
you can change the setting so there is no break in the output on the ASA:
pager 0
Setting it to 0 means no break line.
If you want to run long output for example: show tech, or show run, then quickly change the pager to 0, and change it back to number of lines you want before break (by default it's 24 lines).
Super Bronze
Bronze
Hi Jennifer,
Thanks for your help. I do use this feature at the moment, but I find every break in the output (where you need to hit space to see more) gets recorded which leaves the file quite messy. I usually have to edit the file afterwards so it reads clearly.
I wondered if there is a way for the asa to write the output directly?
Paul
Super Bronze
pager 0
Bronze
Ah magic!
Thanks Jennifer, i'll give this a go.
Bronze
Just tried this and it worked great.
Thanks for your help Jennifer
1560
