Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
How to set a maximum download size per connection in the ASA?
Hi, I would like to avoid big downloads so I want to set a maximum download file size. How can I set the limit MB allowed per connection in the ASA?
1 ACCEPTED SOLUTION
Yes, you will be able to do that using the Modular Policy Framework (MPF)
access-list test permit tcp host x.x.x.x host y.y.y.y eq 80
class-map test
match access-list test
policy-map global_policy
class test
set connection timeout x.x.
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hello Jmprats,
Being honest to you I know we can configure timeouts for particular connections or the maximun amount of connections per host.
We can also configure the maximum bandwitht that a particular traffic pattern can have but I am almost sure there is no option to limit a connection based on the download size of a connection ( ASA speaking)
Julio
Julio Carvajal
So, I suppose I will have to work with connections timeouts. Can I set different timeouts for differents source ip address?
class-map test
class test
Julio
Julio Carvajal
Is it possible to set connection tieout in the newer versions (ie 8.4, 9.1)? Not idle or tcp-embriotic or smth, but timeout for regular legitimate connections. Just as on example in previos post. In newer version i don't see such option. Any clue?
Silver
Are we talking about a "timeout" for normal and working connections?
The function of the current timeouts is to free resources on the unit and provide protection.
I'm not sure u answered my question. Look at previos post by jcarvaja. See the commands? (particulary
set connection timeout x.x.). Is there a way to achieve this in newer versions. I.e. not set conection timeout idle/half-open/embriotic, but just set connection timeout without any other keywords.
Re: How to set a maximum download size per connection in the ASA
Hello Andrew,
I got your question, but I think we might be confused here, I did not specify something after the timeout but when you configure it you will see you have the same options
Here is the configuration options on 8.2.5
ciscoasa(config-pmap-c)# set connection timeout ?
mpf-policy-map-class mode commands/options:
  dcd          Configure dead-connection-detection retry interval.
  embryonic    Configure absolute time after which an embryonic TCP connection
               will be closed, default is 0:00:30.
  half-closed  Configure idle time after which a TCP half-closed connection
               will be freed, default is 0:10:00
  idle         Configure idle time after which a connection state will be
               closed.
Now on an ASA running 8.4.4(9)
WPLG-ASA-1(config-pmap-c)# set connection timeout ?
               closed.
So as you can see same options, no change at all
Hope that I could help
Remember to rate all of the helpful posts
Julio Carvajal
I always thought that it was possible to generaly limit conn timeout for specific set of traffic (), but, as it turned out it can't be done. Interesting)
Hello Andrew,
yeahp
Julio Carvajal
And back to the original question. Is there any way to monitor who is uploading or downloading?
I can monitor connection MBytes, but I cannot see which direction they are (upload or download).
Why dont you use Netflow on the ASA...
Of course you will need a software to be able to understand the netflow traffic from the ASA ( Records and templates), I would even recommend you to go with the PRTG software, a beauty that is for free ( just to 1 to 10 devices) and it will show you that stuff
Go ahead and get PRTG and enable SNMP on the ASA,
Cheers mate
Julio Carvajal Segura
Julio Carvajal
Thanks, ok I will try
Hey my pleasure,
Julio Carvajal
1782
