how to write a static route between two Vlans
Here is what i need.
Servers at Vlan 6 must see servers at Vlan 2, 10, 11, 12. and and vica versa
How to write the correct commands.
Here is my outputs:
VLAN Name                                                Status    Ports
1    default                                           active             Gi1/0/1, Gi1/0/2, Gi1/0/3, Gi1/0/4
2    ****OFFICE_SERVERS****              active    Fa1/0/13, Fa1/0/14, Fa1/0/15, Fa1/0/16, Fa1/0/17, Fa1/0/18, Fa1/0/19, Fa1/0/20, Fa1/0/25
        Fa1/0/26, Fa1/0/29, Fa1/0/30, Fa1/0/33, Fa1/0/34
4    ****END_USER****                          active    Fa1/0/39
6    ****ILO****                                          active    Fa1/0/1, Fa1/0/2, Fa1/0/3, Fa1/0/4, Fa1/0/5, Fa1/0/6, Fa1/0/7, Fa1/0/8, Fa1/0/9, Fa1/0/10
10   ****WEB****                                      active    Fa1/0/27, Fa1/0/28, Fa1/0/31, Fa1/0/32, Fa1/0/43
11   ****APP_SERVERS****                    active    Fa1/0/11, Fa1/0/12, Fa1/0/21, Fa1/0/22, Fa1/0/35, Fa1/0/36
12   ****DB_SERVERS****                    active    Fa1/0/23, Fa1/0/24, Fa1/0/37
99   ****VISITORS****                           active
Gateway of last resort is 192.168.0.253 to network 0.0.0.0
C    192.168.10.0/24 is directly connected, Vlan100
172.16.0.0/24 is subnetted, 6 subnets
C       172.16.29.0 is directly connected, Vlan99
C       172.16.30.0 is directly connected, Vlan6
C       172.16.9.0 is directly connected, Vlan3
C       172.16.10.0 is directly connected, Vlan4
C       172.16.0.0 is directly connected, Vlan1
C       172.16.1.0 is directly connected, Vlan2
C    192.168.0.0/24 is directly connected, Vlan5
S*   0.0.0.0/0 [1/0] via 192.168.0.253
Everyone's tags (2)
1 ACCEPTED SOLUTION
It appears to be switch configuration. If you create Vlan interface on this switch, as these are drectly connected subnets, they should able to communicate.
hth
MS
1 REPLY
hth
MS
795
