Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
HTTP(S) Connection Timeouts for ActiveSync DirectPush AUTD Heartbeats
I am getting errors from Microsoft Exchange ActiveSync due to HTTP(S) Connection Timeouts on HTTP(S) heartbeats. The minimum timeout is 15 minutes but recommended timeout is 30 minutes. Where do I change the minimum connection timeouts on a PIX running 6.3(5) PDM 3.0(4)? It seems that the TIMEOUT CONN command would cover this.
My current settings are below.
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
Microsoft support article ID: 905013
1 REPLY
Silver
Re: HTTP(S) Connection Timeouts for ActiveSync DirectPush AUTD H
"timeout conn HH:MM:SS" would change the timeout for conn. But as you can see from your post it is already 1 hour which is the default. That is more then enough then the 30min recommended.
Chad
514
