Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Bronze
HTTPS Authentication issue on ASA
Hello experts,
I'm doing authentication on the firewall for HTTP and HTTPS traffic. It is working fine for the HTTP, but it does not work for HTTPS, do I require virtual http? even with that I was not getting the prompt, I was able to access directly... this is my configuration:
test(config)# sho run
ASA Version 8.0(3)
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 192.168.180.96 255.255.255.0
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 192.168.100.1 255.255.2
access-list aaa extended permit tcp any any eq www
access-list aaa extended permit tcp any any eq https
nat-control
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 192.168.180.5 1
aaa authentication match aaa inside LOCAL
username test password xxx encrypted
Community Member
Re: HTTPS Authentication issue on ASA
Are talking about https for the asa it self? if so then put in http server enable
Kev
Community Member
No need virtual http for https authentication as I know.
https also supportoted for proxy authentication as http
167
