https port-forwarding
Dear The Expert,
I am trying to https (443) port-forwarding.. tried below, but not working ;>(
static (inside,outside) tcp X.X.X.X https I.I.I.I https netmask 255.255.255.255 0
access-list inbound_filter permit tcp any host X.X.X.X eq https
clear xlate
wr m
what I missed? .. is there any difference method for doing https port-forwarding?
many thanks..
regards
Winanjaya
Re: https port-forwarding
That is right. Did you see any increments on the ACL?
XXX should be your global ip and III should be your local.
Check the mask that you have in the static also, did you mean 255.255.255.255?
I hope it helps.
PK
225
