https port-forwarding
I am trying to https (443) port-forwarding.. tried below, but not working ;>(
static (inside,outside) tcp X.X.X.X https I.I.I.I https netmask 255.255.255.255 0 0
access-list inbound_filter permit tcp any host X.X.X.X eq https
clear xlate
wr m
what I missed? .. is there any difference method for doing https port-forwarding?
Re: https port-forwarding
The configuration is correct.
Is the https service running on the server ?
Check out the https services are running or not !!
Ganesh.H
Is the access-list inbound_filter applied to the outside interface.
Check for the command: access-group inbound_filter in interface outside
If the above mentioned command is present with the configuration that you mentioned, then you need to check the https services on the server. Also, check if you see hit counts on the access-list.
Sai
What is the IP address? Is it the interface IP address? If so you need to use the keyword "interface" and not IP address x.x.x.x.
If it is the interface then do you have asdm enabled on the same port? If so, this traffic is destined TO the box and not THROUGH the box.
-KS
Hello all,
Thanks a lot!.. this already resolved.. the problem occurs because the http server not configured correctly..
regards
Winanjaya
342
