Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
ICMP through an ASA running 8.4
I have a one-to-one NAT configured (mail <-> xenon), however, I am unable to configure ICMP to respond on the external IP of the NAT.  Below is my config, there is extra ICMP cruft that I have been trying that is probably not necessary, but any help with this problem would be helpful
# sho run
ERROR: % Invalid input detected at '^' marker.
ciscoasa# sho run
: Saved
ASA Version 8.4(2)
hostname ciscoasa
enable password psKHILtBkc/R7/X9 encrypted
passwd psKHILtBkc/R7/X9 encrypted
names
interface Ethernet0/0
switchport access vlan 2
speed 100
duplex full
interface Ethernet0/1
interface Ethernet0/2
switchport access vlan 3
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
speed 100
duplex full
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.90.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address xxx.xxx.xxx.124 255.255.255.248
boot system disk0:/asa842-k8.bin
ftp mode passive
same-security-traffic permit inter-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network mail
host xxx.xxx.xxx.125
object network xenon
host 192.168.90.252
object network public
host xxx.xxx.xxx.126
object network helium
host 192.168.90.249
access-list outside_access_in extended permit tcp any object xenon eq www
access-list outside_access_in extended permit tcp any object xenon eq https
access-list outside_access_in extended permit tcp any object xenon eq 587
access-list outside_access_in extended permit tcp any object xenon eq smtp
access-list outside_access_in extended permit tcp any object xenon eq 993
access-list outside_access_in extended permit tcp any object xenon eq 5666
access-list outside_access_in extended permit tcp any object xenon eq ssh
access-list outside_access_in extended permit tcp any object helium eq https
access-list outside_access_in extended permit icmp any object xenon echo-reply
access-list outside_access_in extended permit icmp any any echo
access-list wccp_redirect extended deny ip host 192.168.90.11 any
access-list wccp_redirect extended permit tcp 192.168.90.0 255.255.255.0 any eq www log
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any echo-reply inside
icmp permit any echo inside
icmp permit any outside
icmp permit any echo outside
icmp permit any echo-reply outside
no asdm history enable
arp timeout 14400
nat (inside,outside) source dynamic any interface
nat (inside,outside) dynamic interface
nat (inside,outside) static mail
nat (inside,outside) static public
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 xxx.xxx.xxx.121 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication http console LOCAL
aaa authentication telnet console LOCAL
aaa authentication ssh console LOCAL
wccp web-cache
wccp interface inside web-cache redirect in
Everyone's tags (4)
Hello Munroe,
Add the following command:
-Fixup protocol ICMP
Please provide the following output:
packet-tracer input outside icmp 4.2.2.2 8 0 mail_ip
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
# fixup protocol icmp
INFO: converting 'fixup protocol icmp ' to MPF commands
ciscoasa# packet-tracer input outside icmp 4.2.2.2 8 0 xxx.xxx.xxx.125
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
NAT divert to egress interface inside
Untranslate xxx.xxx.xxx.125/0 to 192.168.90.252/0
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect icmp
service-policy global_policy global
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 7
Type: DEBUG-ICMP
Subtype:
Result: ALLOW
Config:
Phase: 8
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 9
Type: DEBUG-ICMP
Subtype:
Result: ALLOW
Config:
Phase: 10
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 11
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 2298729, packet dispatched to next module
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: allow
ciscoasa#
Hello Munroe,
The Packet tracer shows that everything is allowed, please let me know if its working or if we need to do further investigation ( Next thing would be captures)
Julio
Julio Carvajal
Super Bronze
Re: ICMP through an ASA running 8.4
Is this ASA configured for some companys production environment or test purposes?
Just wondering if the server has default GW set in its configurations? This would explain a situation where it replies to ICMP directly from ASA but not from Internet (because ICMP is not coming from a connected network of the server) Though you didnt say does it respond to ICMP from the local network of 192.168.90.0/24
Just thought I'd ask as Julio said, there packet tracer goes through fine.
Also is there anything on server that might block the ICMP echos?
- Jouni
11176
