ICMP Traffic on an 877 with 8 IP addresses
I have always wondered what is regarded the best setup for ICMP traffic with 8 IP addresses. I am using Multi-Nat on an 877W router.
Basically, what types should be allowed out and in to my network, should I allow it to just the router IP address, or the others as well, im guessing the broadcast address may be a bad idea, so far im using this setup
incoming, only to router address.
access-list 102 permit icmp any host 217.155.xxx.xxx echo
access-list 102 permit icmp any host 217.155.xxx.xxx echo-reply
access-list 102 permit icmp any host 217.155.xxx.xxx time-exceeded
access-list 102 permit icmp any host 217.155.xxx.xxx unreachable
access-list 102 permit icmp any host 217.155.xxx.xxx source-quench
access-list 102 permit icmp any host 217.155.xxx.xxx packet-too-big
access-list 102 deny icmp any any
outgoing i allow all ICMP
Re: ICMP Traffic on an 877 with 8 IP addresses
Preferred incoming ICMP from internet should be limited to echo, unreachable and time-exceeded only. Deny others.
But if you want trusted external host to be able to ping the IP(s), allow echo-reply on the specific ACL permitting the source/destination address.
AK
Gold
You should permit following (deny other ICMP traffic)
echo type 8 code 0 purpose--> Ping
echo-reply type 0 code 0 purpose--> Ping response
unreachable type 3 code 4 purpose--> Used by path MTU to determine the optimal MTU setting
ttl-exceeded type 11 code 0 purpose -->TTL expired in transit. Used by traceroute
M.
Hope that helps rate if it does
127
