Identifying Manual NAT in ASDM
Hi Everyone,
Below is the screenshot from Cisco LEarning Website for ASA  Practice test.
Correct answer is Manual NAT polices .
Need to  know what should i look for in ASDM  that will tell me it is Manual NAT?
MAhesh
Message was edited by: mahesh parmar
2 ACCEPTED SOLUTIONS
Super Bronze
Well the first thing I notice in the picture is that the ASDM says in the middle "Network Object" NAT (No Rules)" which basically tells us that there are no Auto NAT / Network Object NAT configured.
We also know that there is only 2 different NAT Rule Types. Manual NAT and Auto NAT (Network Object NAT) and the ASDM already tells us there is no Auto NAT rules (above explanation) then we can conclude that what we are seeing is a Manual NAT rule.
- Jouni
Hall of Fame Super Silver
Re: Identifying Manual NAT in ASDM
It is manual because the screenshot shows that there are no Network Object NAT rules. So the displayed NAT rule is of type #3 in the list below.
In ASA 8.3 or later there are 3 types of NAT rules you can add:
1. Manual NAT before Network-object NAT
2. Network-Object NAT (network-object NAT is also known as AutoNAT)
3. Manual NAT after Network-object NAT.
If you looked at the cli, it would have the keyword "after-auto" in the NAT rule.
Super Bronze
There is no picture in your post. Atleast yet.
As soon as you can attach it I can take a look at it though ASDM is not my strong point as I rarely use it but I'd imagine I can answer this.
- Jouni
Hi Jouni,
Sorry for that.
Screenshot is added now.
MAhesh
Super Bronze
- Jouni
Hi Jouni & Marvin,
Many thanks for sharing valuable info with me.
I can learn a lot from you.
Best Regards
MAhesh
274
