if we enable IP audit feature in physical interface, will it apply to sub-interface too ?
Hi - I have a query regarding the ip audit option in Cisco ASA, We have enabled IP audit features in outside physical interface and that interface is split into 2 sub-interface. Will it be effect in both sub-interfaces ? Pls clarify.
2 ACCEPTED SOLUTIONS
VIP Green
I do not believe that it will affect the subinterfaces.  When assigning the audit policy to an interface you need to specify the interface name and the policy only affects that specific interface even if there are subinterfaces associated with that physical interface.
You can easily check this by issuing the command show ip audit count interface for each interface.  You will see that only the physical interface will have any signatures associated with it while the subinterfaces have none.
Please remember to rate and select a correct answer
That is correct.  There is no inheritence of policy based commands from the physical interface to sub-interfaces.
Sincerely,
David.
VIP Green
Sincerely,
David.
Thanks. I have verified it. Now i understood.
285
