Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
IKE Does Not Start
I have an ASA5510. When I put the command 'crypto map MAP 20 set peer a.b.c.d', an error message "[IKEv1]: Ignoring msg to mark SA with specified coordinates <MAP, 20> dead" comes out. What does this mean?
When I turned out debug crypto isakmp 127, no messages come out.
How can I start IKE?
Thanks in advance.
Community Member
Re: IKE Does Not Start
I am not sure about your full configuration, but if you want to enable ISAKMP on a specific intrface use the command:
Crypto isakmp enable interface_name
The ISAKMP should start when you define this, if this is not the case, post your config, and make some debugging, for isakmp and ipsec.
regards
Community Member
It starts working after a reload.
Thanks for your response
522
