Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Implementation problems with Botnet on ASA-Context FW
I'm currently trying to implement a trial Botnet Traffic Filter on a ASA5520 multicontext.
It's running in a data center, with ~10 customer contexts. When I tried to enable it, we had a bunch of dropped pings on different contexts. I'm not really sure if there is anything wrong in the configuration, or if this is some kind of bug, or even normal behavior.
Licence is activated.
My config:
admin-context:
dns domain-lookup outside
dns server-group DefaultDNS
name-server 8.8.8.8
system-context:
dynamic-filter updater-client enable
customer-context:
dynamic-filter use-database
access-list dynamic-filter_acl extended permit ip 10.140.1.0 255.255.255.0 any
dynamic-filter enable interface outside classify-list dynamic-filter_acl
policy-map global_policy
 class inspection_default
  inspect dns dynamic-filter-snoop
After implementing the commands on the system/admin context, the pings to google.com started to drop (4 drops, 6 ok, 3 drops, 10 ok, 1 drop, 1 ok,...).
Has anyone an idea how we can get this runnning without impact on our customers?
Amir
1 REPLY
Hi Amir, Its advised to use
Hi Amir,
Its advised to use the local dns or your isp provided dns.... that also could be the reason... also you are filtering for one subnet which should not affect the other context or users.....
Karthik
108
