Impossible to redirect traffic from Outside to Intranet
I use Annyconnect to permit connection of remote clients
to Inside network.
Pool for remote clients 192.168.10.1-100
internal network 192.6.0.0
Anyconnect works fine to access the internal network but now the customer would like that the remote clients
with an IP address in 192.168.10.x could access directly equipements
on the distant site (Subnet 172.16.10.0)  through the Intranet interface (no VPN on Intranet interface, connected to MPLS)
Intranet interface has an IP address in 192.168.1.0.
Here is the path for the traffic:
Annyconnect clients 192.168.10.1-100 --> Outside  'FW'   Intranet -->  Distant network 172.16.10.0
# Security-levels on the ASA 5510 cluster at rel 8.4.7
Inside 100
Outside 0
Intranet 50
Since we don't have the same security level for Intranet and Outside
i have first proposed to create an access-list which permit ip from 192.168.10.1-100 to 172.16.10.0
applied Outbound on the Intranet interface  but it doesn't work
Then i have tried to apply the same access-list Inbound on the outside interface but same issue.
I would like if there is something special to do.
We don't apply NAT on Intranet interface, the remote ASA firewall has been configured to see as Source IP
the anyconnect IP address 192.168.10.1-100
Best regards.
A-Even
1 REPLY
Hello,First of all traffic
First of all traffic from the clients going to the Distant network will not need any sort of FW Access-List due to the sysopt connection permit-vpn.
What you will need to do is:
-If using any sort of split-tunneling make sure you allow the traffic to the distant network.
-Make sure the devices behind the MPLS network know that in order for reach that VPN Anyconnect Pool of addresses they need to send the traffic to the ASA.
-Make sure the NoNat Rule on the ASA includes traffic from the distant Interface to the VPN Anyconnect Pool.
-If any ACL on the Intranet interface, allow the traffic that will be generated from the distant network.
Does it make sense?
Jcarvaja,
Remember to rate all of the helpful posts!!!!
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
57
