Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Inbound TCP connection denied from x to y
Hi Everyone,
Seeing following logs on ASA:
  Inbound TCP connection denied from x to y flags SYN ACK on interface Net
  Inbound TCP connection denied from x to y flags ACK on interface Net
Does this mean that there is Asymmetric route or missing ACL?
MAhesh
1 ACCEPTED SOLUTION
Hello Maheshm
First option Asymmetric routing, use the TCP state-bypass option as a workaround.
Remove the asymetric routing as the real fix
Check my blog at http:laguiadelnetworking.com for further information.
Cheers,
Julio Carvajal Segura
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hello Maheshm
Cheers,
Julio Carvajal
Hi Julio,
I tested my applying ACL   so you are correct its Asymmetric routing.
MAhesh
Hello Mahesh,
Thanks for the head´s up.
Cheers,
Julio Carvajal
289
